XS1930-12HP: set date and time
AchimKlausmann
in Switch
i want to set correct date an time via GUI. Is it possible?
If i set it in 'Basic Seting' / 'Gerneral Setup', it will not be stored after klicking on Apply.
Is it not possible from remote?
What can i do?
Best Regards
Best Answers
Hi @AchimKlausmann,
Did you change the "Use Time Server when Bootup"?
Please change it to None before changing the date/time in the New date/New time column.
Below is the result.
Zyxel Melen0 -
Thank you for your answer.
Yes i found it out by myself.
Best Regards
Hi @AchimKlausmann,
Zyxel Melen0 -
Best Regards
- 603 USG FLEX H Series
- 481 News and Release
