XS1930-12HP: set date and time
AchimKlausmann
AchimKlausmann Posts: 2  Freshman Member
i want to set correct date an time via GUI. Is it possible?
If i set it in 'Basic Seting' / 'Gerneral Setup', it will not be stored after klicking on Apply.
Is it not possible from remote?
What can i do?
Best Regards
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,697  Zyxel Employee
    Hi @AchimKlausmann,
    Did you change the "Use Time Server when Bootup"?
    Please change it to None before changing the date/time in the New date/New time column.
    Below is the result.
    Zyxel Melen
  • AchimKlausmann
    Thank you for your answer.
    Yes i found it out by myself.
    Best Regards
  • Zyxel_Melen
    Hi @AchimKlausmann,
    Zyxel Melen
  • AchimKlausmann
    Best Regards
