SecuExtender is not supported on MacOS 15 (Sequoia)
guys please try to at least remove the version check. please!
Maybe this is why Zyxel has decided not to support Mac OS 15
https://techcrunch.com/2024/09/19/apples-new-macos-sequoia-update-is-breaking-some-cybersecurity-tools/
more likely they will switch to Nebula subscription based services from on premise licensing. Statement is clear - end of life cycle. Installers will be removed at the end 2024. You don’t ignore macOS version for your product “just” because it breaks your software. You have to adapt and remove the problem.
According to the same article, more than one security software companies are waiting for updates/patches from apple, before declaring compatibility with latest MacOS.
Feel free to knock on Cupertino's door for explainations and ETA about .0.1 update.
I hardly suggest to early major release upgrades.
Any further news please on an update for this one?
Good morning, we also have the same problem on some mac clients. Can you give us an indication to get an update of the application? Thanks
Dear all,
Since the SecuExtender SSL VPN macOS version is EOL, please refer to this article for upgrade options. Thank you!
[2024 Sept Notification] SecuExtender SSL VPN macOS and Windows Clients: EOL and Upgrade Options
Don't miss this great chance to upgrade your Nebula org. for free! https://bit.ly/4g2pS9L
Good morning,
version 1.2.6 is the one we have already installed but it is the one for which we have the incompatibility problem with mac. We need to have a resolution because the users of our company cannot connect to the network. Can you give us a valid solution?0 -
Thank you for your update. May we know which firewall model you are using? Also, is it in Nebula mode or on-premise mode?
Thanks.Don't miss this great chance to upgrade your Nebula org. for free! https://bit.ly/4g2pS9L
Hi, the firewall we are using is zyxel vpn 100. Local mode not cloud.
- 414 Beta Program
- 2.3K Nebula
- 139 Nebula Ideas
- 92 Nebula Status and Incidents
- 5.5K Security
- 196 USG FLEX H Series
- 262 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1K Wireless
- 40 Wireless Ideas
- 6.2K Consumer Product
- 241 Service & License
- 379 News and Release
- 80 Security Advisories
- 24 Education Center
- 3K FAQ
- 81 About Community
- 70 Security Highlight
