Frist login after reboot error
PeterUK
PeterUK Posts: 4,427 image  Guru Member
V1.21(ABWV.0)ITS-24WK35-0813-240800592
After a reboot I get this error on first login every reboot
  • Zyxel_Kay
    Hi @PeterUK
    We tested the same firmware version as yours but couldn't replicate the issue you're experiencing. To investigate further, we’d like to remotely access your firewall. I've sent the remote access configuration details to you via a private message. Please check your community inbox.
    Kay
  • Zyxel_Kay
    Hi @PeterUK
    As discussed via private msg., the issue you encountered was resolved with another firmware update. If you experience similar symptoms in the future, feel free to reach out to us.
    Kay
