How can I forward an external WAN IP:PORT to internal LAN IP
MichaelEspinosa
MichaelEspinosa Posts: 1 image  Freshman Member
I have a ATP700 and I have one static public IP address X.Y.Z.T and I want to do forward (virtual server or NAT 1:1) based on the FQDN, so that an external DNS will have:wiki.example.com -> X.Y.Z.Twww.example.com -> X.Y.Z.TThen the atp700 should forward to 10.0.0.1 or to 10.0.0.2 depending on the FQDN.
Is it possible?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,990 image  Guru Member
    Hi @MichaelEspinosa,
    Since you have only one public IP address, X.Y.Z.T, you can only use the "virtual server" for this purpose.
    In addition, the domain name only refers to the IP address. It doesn't refer to the port number. Therefore, you need to use www.example.com:443 → 10.0.0.1:443 and www.example.com:8080 → 10.0.0.2:443.
    Domain name Reference
    Zyxel Melen
