GS1910 - how to limit amount of SNMP output
Hello!
I need to limit amount of the SNMP output because the full info output it required a lot of time and I have a timeouts time to time. For example, I want to limit SNMP output only with
iso.3.6.1.2.1.1.XX,
iso.3.6.1.2.1.2.XX,
iso.3.6.1.2.1.4.XX
and
iso.3.6.1.2.1.5.XX SNMP trees.
Could you please clarify how can I do it?
I tried to do it with SNMPv3 View Configuration, but I can't understand how it works and what the format of the "OID Subtree" filed.
Thanks in advance!
Regards,
Denis
Hi @DenisC,
Since GS1910 is an EOL device, our support is limited. To fulfill your request, you can specify the OID you poll to reduce the output and the polling time.
Hope it helps.
Zyxel Melen0
Hi @DenisC,
Hope it helps.
Zyxel Melen0
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 299 Service & License
- 482 News and Release
