Trying to change web interface from default lan to vlan 100 on a RGS200-12P
Here's the scenario.
An XGS1930 port 26 feeds RGS200-12P port 9.
XGS ports are trunked, passing 100 OK to the RGS.
I have added a IP interface to the RGS on vlan 100. DHCP working OK, the RGS gets an IP on vlan 100. I can ping the IP it gets. I cannot web interface into the switch via this IP however. And when I delete the default interface on VLAN 1, I am locked out of the switch and need to physically reboot it.
I tried adding IP Routes, same issue. But I may not have the correct route.
5 other xyzel switches are configured this same way and I was able to delete the default route without any issues. They are now on management vlan 100. Just stuck on this last switch that wants to be special. Any advice appreciated.
RGS config:
SOLVED in first screenshot, 100 needed to be added to access vlan list!
Here are the config files.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
