SecuExtender is not supported on MacOS 15 (Sequoia)
  • hreba
    hreba Posts: 2  Freshman Member
    guys please try to at least remove the version check. please!
  • RSaull
    RSaull Posts: 32  Freshman Member
    Maybe this is why Zyxel has decided not to support Mac OS 15
    https://techcrunch.com/2024/09/19/apples-new-macos-sequoia-update-is-breaking-some-cybersecurity-tools/
  • hreba
    more likely they will switch to Nebula subscription based services from on premise licensing. Statement is clear - end of life cycle. Installers will be removed at the end 2024. You don’t ignore macOS version for your product “just” because it breaks your software. You have to adapt and remove the problem.
  • mMontana
    mMontana Posts: 1,432  Guru Member
    edited September 2024
    According to the same article, more than one security software companies are waiting for updates/patches from apple, before declaring compatibility with latest MacOS.
    Feel free to knock on Cupertino's door for explainations and ETA about .0.1 update.
    I hardly suggest to early major release upgrades.
  • jackbuchan
    jackbuchan Posts: 7  Freshman Member
    Any further news please on an update for this one?
  • Marcointegrated
    Marcointegrated Posts: 21  Freshman Member
    Good morning, we also have the same problem on some mac clients. Can you give us an indication to get an update of the application? Thanks
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,338  Zyxel Employee
    Dear all,
    Since the SecuExtender SSL VPN macOS version is EOL, please refer to this article for upgrade options. Thank you!
    [2024 Sept Notification] SecuExtender SSL VPN macOS and Windows Clients: EOL and Upgrade Options
  • Marcointegrated
    Good morning,
    version 1.2.6 is the one we have already installed but it is the one for which we have the incompatibility problem with mac. We need to have a resolution because the users of our company cannot connect to the network. Can you give us a valid solution?
  • Zyxel_Jeff
    Hi @Marcointegrated
    Thank you for your update. May we know which firewall model you are using? Also, is it in Nebula mode or on-premise mode?
    Thanks.
  • Marcointegrated
    Hi, the firewall we are using is zyxel vpn 100. Local mode not cloud.
