USG Flex 200H - Real IP for logged in users
Hi @GiuseppeR,
I assume you use the Nebula remote configurator to access your 200H, right?
When you use the remote configurator to establish the remote access address, the Nebula Device creates a reverse SSH (Secure SHell) connection. Therefore, you will see an admin login to the device from 127.0.0.1 in the event log and here.
If you log in via LAN or WAN, the FLEX H will record the correct source IP address.
Zyxel Melen0
Hi @GiuseppeR,
Zyxel Melen0 -
Hello @Zyxel_Melen
yes, you are right. The firewall is on the field for final tests before being in production.
Is there any trick to know which "admin" is connecting from which IP also if it is used Nebula remote configurator ?
I did not find any other areas where to look for logged in users.
Maybe on Nebula portal?
Thanks a lot
Hi @GiuseppeR,
Yes, you may check which admin created the remote configurator tunnel in Organization-wide > Change log. But there is currently some issue: the logs are recorded with the wrong admin. We are fixing it and I will update you once the issue is fixed.
Zyxel Melen0 -
Hi @GiuseppeR,
The log is fixed. You may check who uses remote configurator/remote access to access the USG FLEX H.
Here is an example of when I use the remote configurator/remote access to create a tunnel. The owner is not "nebula cso" in the screenshot.
Zyxel Melen0 -
Hi @Zyxel_May
thanks a lot for this update, I'm going to use it 😁
- 441 Beta Program
- 292 Service & License
