SecuExtender is not supported on MacOS 15 (Sequoia)
guys please try to at least remove the version check. please!
Maybe this is why Zyxel has decided not to support Mac OS 15
https://techcrunch.com/2024/09/19/apples-new-macos-sequoia-update-is-breaking-some-cybersecurity-tools/
more likely they will switch to Nebula subscription based services from on premise licensing. Statement is clear - end of life cycle. Installers will be removed at the end 2024. You don’t ignore macOS version for your product “just” because it breaks your software. You have to adapt and remove the problem.
According to the same article, more than one security software companies are waiting for updates/patches from apple, before declaring compatibility with latest MacOS.
Feel free to knock on Cupertino's door for explainations and ETA about .0.1 update.
I hardly suggest to early major release upgrades.
Any further news please on an update for this one?
Good morning, we also have the same problem on some mac clients. Can you give us an indication to get an update of the application? Thanks
Dear all,
Since the SecuExtender SSL VPN macOS version is EOL, please refer to this article for upgrade options. Thank you!
[2024 Sept Notification] SecuExtender SSL VPN macOS and Windows Clients: EOL and Upgrade Options
Good morning,
version 1.2.6 is the one we have already installed but it is the one for which we have the incompatibility problem with mac. We need to have a resolution because the users of our company cannot connect to the network. Can you give us a valid solution?0 -
Thank you for your update. May we know which firewall model you are using? Also, is it in Nebula mode or on-premise mode?
Thanks.0 -
Hi, the firewall we are using is zyxel vpn 100. Local mode not cloud.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 494 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 48 Wireless Ideas
- 286 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
