Site to site
Good morning,
I have a working configuration with Usg210 site to site with Gateway Edge server farm firewall.
We just purchased a 500 flex.
The site to site configuration procedure is working, but I can't get to the machines behind the edge firewall, which I did before with the 210 easily.
I checked the configurations, I can't recreate just one route (but I think this is the problem) because I'm missing a field. I attach the screenshot. Thanks for the help
Should just be a case of copying the config settings to your Flex500
Maybe the FLEX500 has a LAN subnet the same as the remote end?
Hi Peter, thank you for the reply.I discovered the problem. It wasn't a problem with the additional route, but with a missing firewall rule that routed the LAN traffic to the ipsecvpn.Once that rule was created, everything went back to working normally. Thank you for the quick response and indeed sorry if I was late in replying. Thanks again
- 601 USG FLEX H Series
- 480 News and Release
