L2TP VPN Connection on USG Flex 200 V5.39(ABUI.0) | 2024-08-22
Antares3000
Antares3000 Posts: 26  Freshman Member
I'm trying to configure a VPN on this device. Client can connect correctly. It is ok. If client ping 8.8.8.8 it works. However if client try to navigate www.google.com or some other addresses dosn't work. Cannot understand why dosn't work. I think some rules is missing. In attachment the configuration i did. Can someone help me? Thanks. CB
  • Antares3000
    I solved the problem. In the static rule i changed next hope from the Trunk to the specific WAN channel. I don't know why it dosn't work with trunk setting. I checked trunk setting and there was only the wan channel. So it should be the same. But it seems not.
    PeterUK Posts: 3,461  Guru Member
    seems odd you can connect and ping 8.8.8.8 but not get to google site.
    can you DNS and that the DNS uses your connection
    check your logs for blocked access
    you can make a routing rule for the VPN if needs
    incoming tunnel VPN
    next hop WAN1
  • Antares3000
    check your logs for blocked access → nothing result blocked
    you can make a routing rule for the VPN if needs → i did. you can see the rule in the last page of the pdf document i uploaded in the post. It is done as you said.
    edited September 25
    so can you DNS?
    remove rule 1
  • Antares3000
    so can you DNS?
    what do you mean ?
  • Antares3000
    I've an other similar VPN. Already configured months ago. It worked in the past. Don't know till when. But in august i used it. Now it dosn't work and it has the same problem too. I didn't change anything. Since a long time. Cannot understand what is happening. Maybe a firmware upgrade?
  • Antares3000
    I understood what you mean. No. Doesnt DNS
  • mMontana
    mMontana Posts: 1,389  Guru Member
    50 Answers 1000 Comments Friend Collector Fifth Anniversary
    Do security policies allow from L2TP to "DNS" to Google or other external ip addresses?
  • Zyxel_Judy
    Zyxel_Judy Posts: 1,637  Zyxel Employee
    Hi @Antares3000 ,
    You also can share the remote session information with us to access to your firewall directly for further investigation? If yes, please check the steps on your Community inbox.
    Judy
    See how you've made an impact in Zyxel Community this year! https://bit.ly/Your2024Moments_Community
  • Antares3000
Security Highlight
