Flex H Series - 2FA Page with FQDN
Rathos
Rathos Posts: 6 image  Freshman Member
Zyxel Certified Network Engineer Level 2 - Security Zyxel Certified Network Engineer Level 1 - Security First Comment Friend Collector
Hello together
We would like to have a possibility to assign an FQDN to the 2-FA page. However, this would require the internal DNS to be accessible before verifying with the 2-FA. The reason for our request is that we would like to store a certificate on the firewall so that the browser no longer displays the message that the page is insecure.
Best regards
Niklas R.
System Enginner @ DQ Solutions in Switzerland
8 votes
Active · Last Updated
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @Rathos ,
    Based on your screenshot, it appears you're inquiring about Remote VPN access. When using a remote access VPN to establish a tunnel, all traffic is encapsulated within the encrypted tunnel, so it is acceptable for the 2FA page to use non-HTTPS links.
    To meet your requirements, the 2FA authentication URL can be changed from HTTPS to HTTP. For example, changing from https://10.10.1.2:4433 to http://10.10.1.2:4433. Please refer to the configuration here:
    Zyxel_Judy
    Untitled Image
    PeterUK Posts: 4,405 image  Guru Member
    what they want is this from FLEX200
    Screenshot 2024-09-20 044241.png Screenshot 2024-09-20 044147.png Screenshot 2024-09-20 044210.png
  • Rathos
    Hi Judy
    We would still prefer using an FQDN for a more professional appearance. Would we be able to switch to User-Defined and then access the authorization page via an FQDN using the WAN IP, as Peter mentioned?
    Best regards
    Niklas
  • Zyxel_Judy
    Hi @Rathos ,
    You can try to use the configuration on H series.
    Zyxel_Judy
    Untitled Image
    edited October 2024
    Problem is Judy it don't work it uses the default certificate
  • Zyxel_Judy
    Hi user,
    We are considering this as a potential feature for future evaluation. We'll investigate carefully about that.
    Zyxel_Judy
    Untitled Image
