FlexH Series GeoIP custom gruop
Mk88_it
Mk88_it Posts: 75 image  Ally Member
Now if i want to create an address group with more GeoIP Region abjects, i have to create all address objects with GeoIP Region one by one.
I think it could be easier to have the possibility to create a custom GeoIP group in the GeoIP section directly.
Thank you
2 votes
Active · Last Updated
  • Zyxel_Kay
    Hi @Mk88_it
    To clarify, are you proposing that users should have the ability to manually create and add a custom GeoIP group directly in the Object > Address > Geo IP section?
    Kay
  • Mk88_it
    Yes!
  • Zyxel_Kay
    Hi @Mk88_it
    Thank you for your feedback and input! We'll be monitoring the votes and comments as part of our evaluation process.
    If anyone likes this idea, please show your support by leaving a comment or voting for it.
    Kay
