VPN100 - ATP500 ipsec test speed
Hi
I try to optimize my VPN between VPN100 (Company) ans ATP500 (Datacenter)
HTTP/HTTPS + Windows networking (Windows 2012/2016 File sharing, RDP...) will be used on this VPN
Datacenter-Internet Link is 1G/1G
Datacenter network is 2x10G
Company-Internet is 1G/500Mbs
Actually :
Ping is 4ms (10ms when iperf test full)
iperf give me 150Mbs/125Mbs
iperf (-P 8) give me 350Mbs/145Mbs
Windows File transfer is 20MB/s (Mo/s)
What setting I must look ? (mtu ? window size ?, other ?) and how ?
Best Answers
@Cyrille
The throughput of IPsec VPN from specification is UDP session, so the throughput will be 500 Mb/s(IXIA machine).
As I tested locally with your configuration, the throughput of VPN is around 170 Mb/s.(j-perf, TCP session). However, the statistic of throughput may be different by test machine or test process.
Charlie5 -
Ok, Accepted solution. VPN100 VPN real throughput is less than 200Mb/sZyxel_Charlie said:As I tested locally with your configuration, the throughput of VPN is around 170 Mb/s.(j-perf, TCP session).
Regarding to VPN throughput case,
the VPN throughput of VPN 100 is around 500Mbps.(VPN100---VPN----Specific test Machine).
Moreover, we also have run a similar lab test internally between two VPN 100 using Windows File transfer.
Download Transfer speed is around 25-32.5Mbps.
We suggest you replace AES256 with 3DES to get better throughput.
Test: PC doing Windows File transfer to another PC directly.
As our lab, there is only one vpn tunnel, however, there are more than one VPN tunnel are working on customer site, therefore, the throughput may be lower than our result.
Charlie
Thanks for your answerOnly one VPN is active when i do test.Settings are :Phase 1 - IKE v2, PSK, Life time 86000, AES256, SHA1, DH5Phase 2 - 28000, AES256, SHA1, DH5MTU is 1500 by defaultRobocopy /MT:8 is 110 Mb/s / 145 Mb/s ( < 20MB/s)Maybe it's MTU. Do you have kb to find/setup best MTU ?Thanks
@Cyrille
Regarding to this case,You can try to change the AES256 to 3DES and see if the throughput is getting better.
Also, the Maximum MTU size of USG Series is 1500 which is better value for throughput.
Charlie0 -
Changing phase 2 AES256 to 3DES don't change speed. 110Mb/s - 140Mb/s
@Cyrille
since the throughput of Windows File transfer on my local test is better than yours(5Mbps-10Mbps), therefore, can you private message your configuration for testing?
Charlie0 -
@Zyxel_CharlieHave you test my config ?Do you get more than 200Mb/s with VPN 100 ? Specifications tells 500 Mb/s but maybe VPN 100 specifications are wrong and 500 Mb/s -> 1/3 -> 166Mb/s maximum ?
@Cyrille
Charlie5 -
- 441 Beta Program
- 292 Service & License
