USG700 Bridged WAN interface how to setup trunk
PlusAuto
PlusAuto Posts: 7  Freshman Member
We have a USG700 with bridged WAN interface (BR1) on ports GE1 and GE2.
There is a dual fiber uplink from our ISP we bridged the interface.
This how it looks
2024-09-26 15_35_29-[USGINTERDC] (178.251.30.21_8443) - .__ Welcome to USG FLEX 700 __. – Mozilla Fi.png
Then we setup a WAN TRUNK but i`m not really sure if its needed and if needed how to properply set this up.
2024-09-26 15_36_31-[USGINTERDC] (178.251.30.21_8443) - .__ Welcome to USG FLEX 700 __. – Mozilla Fi.png
We have setup the trunk with only one member (BR1) and is set to active.
Or should we add GE1 and GE2 as members?
If so then we should probably undo the bridged wan interface?
Any thoughts on this?
Note : Everything seems to be working fine.
    PeterUK Posts: 3,887  Guru Member
    edited September 2024
    interesting way you set it up so you only get one WAN IP?
    or if you set ports without a bridge do you get two WAN IP's? do you have a subnet of WAN's IP's?
  • PlusAuto
    We have 1 main IP adress that is set on the bridge interface. After that we assign servers an own external IP with SNAT rules, this in our subnet of WAN ip`s
    So if you do a packet capture on Ge1 and Ge2 do you send like ICMP or TCP SYN out each interface when you send one?
    or have you tested removing Ge1 that Ge2 take over and the other way round?
  • PlusAuto
    Well it seems that one interface does all the work
    GE2: .CAP file contains entries.
    55 packets captured
    77 packets received by filter
    0 packets dropped by kernel
    GE1: .CAP file contains no entries.
    0 packets captured
    2 packets received by filter
    So if you unplug Ge2 that GE1 takes over?
  • PlusAuto
    That is how it normally works yes, i can not test it at the moment as the site is 1 hours drive away
    I'm also thinking what about a LAG instead of a bridge?
  • PlusAuto
    Im not really sure , i never used LAG.
    I thought a bridge setup is kind of the same?
    well your setup works so should be fine
