Whitelisted IPs
CLOODY
CLOODY Posts: 14 image  Freshman Member
edited September 2024 in Security
Good morning I wanted to ask how to authorize an ip to my website protected by ATP200.
My security Plicy is configured to allow only Italian addresses. I need to authorize some IPs from other countries, I added them in the allow List of the Reputation Filter/IP Reputation of the Security Service section
Is it correct or do I have to do something else
Thank you
  • jonatan
    jonatan Posts: 200 image  Master Member
    5 Answers First Comment Friend Collector Eighth Anniversary
    @CLOODY
    Use Geo-IP, add the necessary IP addresses indicating the country of origin, and the gateway will let them through.
    There should also be an appropriate policy for switching from a global network to a local one for the necessary service.
    In the object type GEOGRAPHY , region Italy. and in the policies in the source, select it for long-term access from all italy addresses
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,633 image  Zyxel Employee
    Hi @CLOODY
    Configuring these IP addresses in the allowed list of the IP Reputation cannot fulfill your requirement. Please reference the steps that @jonatan provided.
    Zyxel Melen
  • CLOODY
    Ok Provo quanto descritto da @Jonatan
  • zyman2008
    zyman2008 Posts: 243 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    I think it not a good approach to add the IP address into Geo/Country in this case.
    From the security operation point of view.
    To add another security policy with address group object is the right way to fit that.
    (1) It's more visible the full rules on the same security policy page.
    (2) You can identify firewall logging by different rule number.
    (3) You can easy to enable/disable rules for troubleshooting.
    (4) It don't cause misuse the Geo Country object if the Country object using on the other policy.
  • CLOODY
    Sorry I didn't understand well. Two criteria, one that allows only IPs from Italy and another that authorizes some IPs even if not Italian, can both coexist and do they both rule?
  • jonatan
    @CLOODY
    If the request is for the same service, then the rules will mutually exclude each other. The one above the list will work.
