200H Not possible to disable, edit or remove default global zone forwarder.
bbp
bbp Posts: 68  Ally Member
First Answer First Comment Friend Collector Sixth Anniversary
200H - firmware 1.21
Why is it not possible to disable, edit or remove default global zone forwarder?
System→DNS & DDNS→Global Zone Forwarder
    PeterUK Posts: 3,999  Guru Member
    edited September 2024 Answer ✓
    Yes I hate it too but its been that way for other models
    but here is a way on DHCP to not request DNS but I have not tried it as I block ISP DNS by other means
    https://community.zyxel.com/en/discussion/comment/64690/#Comment_64690
    What should happen when you have no added DNS forwarders is it becomes a recursive DNS resolver
  • bbp
    Interesting 'workaround'.
    Thank you Peter.
