VLAN Seperation
2»
  • VCS
    VCS Posts: 19 image  Freshman Member
    It comes from port 9 which is connected to a Samsung TV.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,615 image  Zyxel Employee
    Hi @VCS,
    Thanks for the information. Since the monitoring port, port 10, will receive its subnet traffic and the mirroring ports' traffic, you will find the broadcast traffic from many subnets. To better verify whether the VLAN setting works, could you connect your PC directly to the VLAN ports you are concerned about?
    Zyxel Melen
  • VCS
    Thanks to pointing that out. Will put it into VLAN ID 2.
  • VCS
    I have changed port 10 so to allow tagged VLAN ID 4, blocked VLAN ID 1 and changed the PVID to 2.
  • VCS
    I thanks the issue is solved as pvid 1 was stille connected to port 10 which causes local lan traffic also arrives at port 10.
