USG Flex 700H Bridge Interface to group individual ports
phayze
phayze Posts: 34 image  Freshman Member
edited September 2024 in USG FLEX H Series
As the 2 SFP+ port on Flex 700H is considered individual port and cannot be group together. Can we use the below example to create a bridge to overcome this as the below example is on different platform as Flex 700? Is there any guide or example on Flex 700H platform?
USG FLEX / ATP: Bridge Interface – Zyxel Support Campus EMEA
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @phayze,
    Please reference the below steps to configure: (I use internal role for example)
      The interfaces after the configuration: image.png
    Hope it helps.
    Zyxel Melen
  • Zyxel_Melen
    Hi @phayze,
    Hope it helps.
    Zyxel Melen
  • AndyY
    AndyY Posts: 4 image  Freshman Member
    does this work also when on each bridge port a single connection to a switch is connected?
