Content Filter
AdminSys
AdminSys Posts: 39 image  Freshman Member
First Comment Eighth Anniversary
edited September 2024 in Security
I would like to ask for help, there is an SSO content filter set up on the firewall, which works fine, but we have set which URL address should be displayed when blocking. This is currently not working.
Setting
This is displayed
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi @AdminSys ,
    To provide you with better support, we need some additional information. Could you please share the following:
    • A screenshot of the "SSO content filter" profile management page
    • Your device's model name
    • The current firewall version you're running
    Zyxel_Judy
    Untitled Image
  • AdminSys
    Hi Judy,
    What exactly do you mean here?
    Model name USG Flex 500
    Firewll version: 5.39(ABUJ.0)
    Because its HTTPS you will not cleanly go to redirect URL you would have to setup SSL Inspection and a Self-signed certificate on device
  • AdminSys
    Hi Peter,
    Thenk you so much it worked
