No default set to open without a random password on all AP shipped
PeterUK
PeterUK Posts: 4,237 image  Guru Member
edited October 2024 in Wireless Ideas
So found out the embarrassing way when checking my traffic the short of it is I setup a AP as Repeater it was on the guest network so its isolated but still can't believe I made this mistake that can happen very easily due to the default set to open and when you make the SSID it set to use the default for Security Profile. I managed to set all the other networks with the right Security Profile just not for the guest network.
Summarize:
I wish for the default to not be set to open just by default its set to WPA2/3 with a random Pre-shared key that can then be changed after.
2 votes
Active · Last Updated
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,153 image  Zyxel Employee
    Hi @PeterUK,
    So your purpose is like your title "No default set to open without a random password on all AP shipped"?
    Zyxel Melen
    So yes as one will be configuring the AP by Ethernet just set a random password per AP for the default Security Profile no need to list it really.
  • Zyxel_Melen
    Hi @PeterUK,
    The latest firmware(V7.00) requires users to change the default SSID setting and security at the first time via the wizard.
    Does this fulfill your request?
    Zyxel Melen
    Its does not fulfill my request I wish for the default to not be set to open just by default its set to WPA2/3 with a random Pre-shared key that can then be changed after.
  • Zyxel_Melen
    Hi @PeterUK,
    Thanks for your feedback. We will monitor and evaluate this request.
    Zyxel Melen
