Enable only Per Vlan RTSP
Experts,
I do have a GS1900-24E with VLAN ID 1, 2, 4.
PVID 2 is used for Internet, PVID 4 is IPTV and PVID 1 is local lan.
I did see some occurrence that STP did mess up with port1 and port 2 which caused that my internet went down for 3 minutes.
How can I enable to do only Per VLAN STP? I have now disabled port 1 and 2 as port 1 connects to the ISP and port 2 to the router (WAN side), port 3 till 8 are used for only VLAN ID (PVID) 4.
All other ports are for local LAN. In theory, I could disable all STP as I do not have a switch which is connected to other switches. I have 2 GS1900E both feeded from the router not not to each other.
Hi @VCS,
What is the difference between info and debug?
They are different log levels. For more information, you may reference these websites:
https://linuxconfig.org/introduction-to-the-linux-kernel-log-levels
https://stackoverflow.com/questions/7745885/log4j-logging-hierarchy-orderWhat means the facility? It says from 0 till 8?
The log facility allows you to send logs to different files in the syslog server. Please refer to the documentation of your syslog program for more details.
Zyxel Melen0
Hi @VCS,
For this purpose, you will need MSTP. However, in normal cases, STP is a function that prevents loops in a ring topology. If your topology is not a ring and you want to prevent loops, you should enable the loopguard function.
By the way, may I know how you determined the issue was due to STP?
Zyxel Melen0 -
Looking better into the pcap file, STP was just sending BDU and did not blocked the port.
Biy blocking the port means that the port remains up only no traffic will passed that port, right?
What I see, that the router reports that his WAN connections goes down but in the log of the switch I do not see anything. It looks like that the router itself has some issues?
Hi @VCS,
Yes, the link status of this port will be link up, but this port is a blocking port so the traffic will not pass/forword.
If the port on switch side wasn't blocking, this issue might be due to the router or ISP(since it was a WAN issue).
Zyxel Melen0 -
One last question, will there be a trap sent when a port is blocked (or port change due to STP) to the syslog?
Hi @VCS,
Yes, you can see the ports are forwarding or blocking in the syslog.
Additionally, you have to change the syslog severity to "info" at least, or you cannot find these logs in syslog.
Syslog > Local:
Syslog > Remote:
Zyxel Melen0 -
What is the difference between info and debug? What means the facility? It says from 0 till 8?
Hi @VCS,
Zyxel Melen0
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
