Does USG LITE 60AX have Schedule profiles ?
Luc_56
Luc_56 Posts: 1 image  Freshman Member
I'm looking for a gateway that can handle scheduling. I have a SCR 50AXE and it didn't support it, but the Flex50 does, but I haven't found any information for the USG LITE 60AX.
Does the USG LITE 60AX support it? Both for Wifi and firewall rules?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,531 image  Zyxel Employee
    Hi @Luc_56,
    USG Lite 60AX supports the SSID schedule, you can find it on the SSID advanced settings page.
    The firewall rules currently do not support the schedule profile. I have helped you create an idea post for this requirement.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Luc_56,
    Zyxel Melen
