SecuExtender disconnected after 8-10 seconds
2»
    Whats your client LAN subnet?
  • simonwong
    simonwong Posts: 14 image  Freshman Member
    LAN-192.168.1.X
    VPN IP POOL-192.168.100.X
    This is my setting.
    So their subnet is not 255.255.0.0
    are you using port 443 for the SSL VPN? as this uses WWW control access
  • simonwong
    I'm using 4433 for SSLVPN
    i cannot find 255.255.0.0, should be 255.255.255.0
    edited October 2024
    Looking at my log vs yours I see one problem maybe? my subnet for the SSL VPN is 255.255.255.0 but yours is 255.255.255.255 ?
    can you try a IP pool subnet
