SecuExtender disconnected after 8-10 seconds
Whats your client LAN subnet?
LAN-192.168.1.X
VPN IP POOL-192.168.100.X
This is my setting.
So their subnet is not 255.255.0.0
are you using port 443 for the SSL VPN? as this uses WWW control access
I'm using 4433 for SSLVPN
i cannot find 255.255.0.0, should be 255.255.255.0
Looking at my log vs yours I see one problem maybe? my subnet for the SSL VPN is 255.255.255.0 but yours is 255.255.255.255 ?
can you try a IP pool subnet
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
