RDP rule for USG50
MattiS
MattiS Posts: 9  Freshman Member
Hello!
I need a walkthrough to make several rdp rules for USG50.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,697  Zyxel Employee
    Hi @MattiS,
    Do you mean remote desktop protocol? What is your scenario?
    Zyxel Melen
  • MattiS
    Yes, port 3389, but I want to change the external port to something else.
    I have several desktops which I have to be able to connect externally, so I need to change the external ports different to every pc, or is there any other way?
    PeterUK Posts: 3,983  Guru Member
    So you need NAT rules and Policy Control like so:
    Policy Control make service group TCP and UDP for port 3389
    From WAN to given LAN
    Service RDP group
    Add a source IP/FQDN for better security if you can
