200H: Device Registration Status: Not Registered
bbp
Posts: 66 Ally Member
Last few days this happens a lot.
You need to improve on that. People rely on security services.
run
tracetcp he.myzyxel.com:443
tracetcp auth-mtls.api.cloud.zyxel.com:443
also ping checks look to be done by TCP 4335
Hi Peter, I have no problem reaching he.myzyxel.com. (traceroute -n -p 443 -T he.myzyxel.com)
Problem is target responds with 'status code 500' when 200H is querying it via API. That's internal server error (codes 5xx) on target side.
Hi @bbp,
May I know if this issue occurred on the device that has been registered? If not, could you send the MAC address and Serial number of that device to check?
Zyxel Melen0 -
Yes, device was previously registered. Sent you serial and MAC in private message.
- 415 Beta Program
- 2.4K Nebula
- 152 Nebula Ideas
- 100 Nebula Status and Incidents
- 5.8K Security
- 285 USG FLEX H Series
- 278 Security Ideas
- 1.5K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 251 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
