200H: Device Registration Status: Not Registered
bbp
Last few days this happens a lot.
You need to improve on that. People rely on security services.
run
tracetcp he.myzyxel.com:443
tracetcp auth-mtls.api.cloud.zyxel.com:443
also ping checks look to be done by TCP 4335
Hi Peter, I have no problem reaching he.myzyxel.com. (traceroute -n -p 443 -T he.myzyxel.com)
Problem is target responds with 'status code 500' when 200H is querying it via API. That's internal server error (codes 5xx) on target side.
Hi @bbp,
May I know if this issue occurred on the device that has been registered? If not, could you send the MAC address and Serial number of that device to check?
Zyxel Melen0 -
Yes, device was previously registered. Sent you serial and MAC in private message.
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
