[2024 Sept Notification] SecuExtender SSL VPN macOS and Windows Clients: EOL and Upgrade Options
Zyxel_JudyH
Zyxel_JudyH Posts: 34  Zyxel Employee
Zyxel Certified Sales Associate First Comment Friend Collector Fourth Anniversary
edited January 15 in Security Highlight
We want to inform you that the SecuExtender SSL VPN macOS and Windows clients have reached their end of life (EOL). Zyxel is no longer selling, maintaining or supporting these products.
However, for those who recently purchased a license, we understand that you may still need access to the software. You can download the software using the archive links below:
Option 1. Use IPSec VPN instead of SSL VPN
IPSec VPN is widely supported across all Zyxel firewalls and endpoint platforms, including macOS, iOS, Windows, and Android. It offers several advantages over SSL VPN:
High Security: IPSec VPN uses multiple encryption and authentication methods, providing strong security and reducing the likelihood of web attacks like cross-site scripting.
High Performance: IPSec VPN often outperforms SSL VPN depending on application and connection conditions.
Network Layer Encryption: Encrypts at the network layer, making it transparent to applications. However, it requires higher technical knowledge to set up and manage IPSec VPN across the board. In Zyxel, we aimed to simplify the process of provisioning IPSec VPN client with a remote VPN wizard (on-prem mode) or using Nebula to generate VPN scripts in just a few clicks.
Alternatively, if you prefer to use free, built-in VPN clients, you can generate VPN scripts via Zyxel's VPN wizard or Nebula’s portal. These scripts are compatible with multiple platforms, including macOS, iOS, Windows, and Android (StrongSwan).
Resources
Watch our video demonstration on using Nebula to provision the new SecuExtender Zero Trust IPSec/SSL VPN Client:
Check out our Zyxel community knowledge base article on how to generate a VPN script for the macOS built-in VPN client. We’ve also completed FAQs to help guide you on using the Sonoma Native VPN client to set up an IKEv2 VPN with your uOS/ZLD on-premise, Nebula firewall, or USG LITE 60AX. You can find the details in the links below:
Why can't I establish a VPN connection after updating to macOS Sonoma? How can I resolve this issue?
If you are a uOS or ZLD on-premise user, check this out: Link
How to establish a VPN connection with a Nebula firewall using the macOS Sonoma native VPN client?
If you are a Nebula firewall user, this guide is for you: Link
How to establish a VPN connection with the USG Lite 60 AX using the macOS Sonoma native VPN client?
If you are a USG LITE 60AX user, take a look here: Link
Feel free to explore these resources!
Option 2. Upgrade to USG FLEX H firewall to continue using SSL VPN
In rare conditions, you may encounter firewall penetration issues when using IPSec VPN. SSL VPN uses HTTPS traffic, making it easier to penetrate firewalls and proxies. For further enhanced protection and comprehensive service features, consider upgrading to a USG FLEX H firewall that supports both IPSec and SSL VPN (OpenVPN). The latest generation solutions offer robust security measures and advanced capabilities to meet your evolving needs. Zyxel's new SecuExtender Zero Trust IPSec/SSL VPN Client supports both IPSec and SSL VPN protocol, plus advanced features: bandwidth throttling, easy provisioning, and tunnel redundancy.
👉️ Try Zyxel's new SecuExtender Zero Trust IPSec/SSL VPN Client for free!
Download the software (30 days free trial included):
macOS version
Windows version
Last but not least, you can use a free OpenVPN client to connect to the USG FLEX H firewall.
  • kyssling
    kyssling Posts: 107  Ally Member
    First Comment First Answer Friend Collector Sixth Anniversary
    Hello, I understand that this is the end of support for SecuExtender, but will SecuExtender continue to work in 2025 ?
  • Zyxel_JudyH
    Hi @kyssling,
    Thank you for reaching out! While it's true that the SecuExtender SSL VPN clients for macOS and Windows no longer receive technical support or software updates, rest assured that if you're using them with their compatible OS versions, they’ll continue to work just fine. Plus, there's no need to worry about any license expiration.
    If you have any other further questions, feel free to ask—we’re here to help!
  • KirillPLT
    KirillPLT Posts: 2  Freshman Member
    SecuExtender SSL VPN client 1.2.6 does not work with macOS 15.0. What program can I use to remotely connect to Zyxel hardware instead SecuExtender SSL VPN client 1.2.6 ?
  • Zyxel_JudyH
    edited November 2024
    Hi @KirillPLT
    Please try our new SecuExtender IPSec/SSL VPN Client for free here: macOS version
    Do you have any additional conditions or scenarios you could share? Feel free to leave us a message—we’re here to help! Thank you.
  • GrahamWebb
    GrahamWebb Posts: 25  Freshman Member
    Hi, we have used the SSL VPN feature with SecuExtender for many years so are now looking at migrating away from the platform due to this announcement, but I have a few questions.
    Firstly, why has this decision been made and is SecuExtender still secure to use?
    Do you have detailed instructions for setting up an alternative IPSec VPN solution for the Zywall Flex 500 (not using Nebula) that will give us a similar experience to the SSL VPN?
    If we upgrade our current Zywall Flex 500 to a Zywall Flex 500H which supports OpenVPN then will licences for the OpenVPN be included with the cost of the router/yearly security update package like the SSL licences are currently? I want to ascertain if there are additional costs other than the router/yearly renewal for using OpenVPN as opposed to SecuExtender SSL VPN?
    Also has an EOL date been announced for the USG FLEX 500 we currently use?
    Kind regards
    Graham
  • GrahamWebb
    Sorry can anyone get back to me on this or should I contact support directly with my question?
  • Zyxel_Melen
    Zyxel_Melen Posts: 2,685  Zyxel Employee
    Hi @GrahamWebb,
    I apologize for the delayed reply. Please allow me to clarify with our team, and I will update you once I have further information.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GrahamWebb,
    > We release new SecuExtender with some enhancement. The old version is still usable for users who already have license and their PC can use the software.
    > Please reference this FAQ:
    https://community.zyxel.com/en/discussion/12522/remote-access-vpn-wizard-for-secuextender-ipsec-and-non-secuextender-ipsec-vpn-clients/p1?new=1
    > OpenVPN doesn't need additional license.
    > No, USG FLEX series haven't announced EOL.
    Hope it helps.
    Zyxel Melen
  • GrahamWebb
    Hi thanks for your reply.
    When you say, "We release new SecuExtender with some enhancement.", do you mean there is a newer enhanced version of SecuExtender that will work with the Zywall USG FLEX 500? I thought the new version ony worked with the newer H series and only as a client for OpenVPN rather than Zyxel SSL VPN?
    Sorry I am finding information conflicting and confusing and I am trying to work out our roadmap for upgrading.
    Thanks Graham
  • Zyxel_Melen
    Hi @GrahamWebb,
    Yes, the new version of SecuExtender also supports USG FLEX/ATP IPSec remote access VPN. SSL VPN only supports for USG FLEX H series.
    Zyxel Melen
