200H: Device Registration Status: Not Registered
bbp
bbp Posts: 68  Ally Member
First Answer First Comment Friend Collector Sixth Anniversary
Last few days this happens a lot.
  • bbp
    You need to improve on that. People rely on security services.
    PeterUK Posts: 3,799  Guru Member
    edited October 2024
    run
    tracetcp he.myzyxel.com:443
    tracetcp auth-mtls.api.cloud.zyxel.com:443
    also ping checks look to be done by TCP 4335
  • bbp
    Hi Peter, I have no problem reaching he.myzyxel.com. (traceroute -n -p 443 -T he.myzyxel.com)
    Problem is target responds with 'status code 500' when 200H is querying it via API. That's internal server error (codes 5xx) on target side.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,277  Zyxel Employee
    Hi @bbp,
    May I know if this issue occurred on the device that has been registered? If not, could you send the MAC address and Serial number of that device to check?
    Zyxel Melen
  • bbp
    Yes, device was previously registered. Sent you serial and MAC in private message.
