SecuExtender disconnected after 8-10 seconds
Whats your client LAN subnet?
LAN-192.168.1.X
VPN IP POOL-192.168.100.X
This is my setting.
So their subnet is not 255.255.0.0
are you using port 443 for the SSL VPN? as this uses WWW control access
I'm using 4433 for SSLVPN
i cannot find 255.255.0.0, should be 255.255.255.0
Looking at my log vs yours I see one problem maybe? my subnet for the SSL VPN is 255.255.255.0 but yours is 255.255.255.255 ?
can you try a IP pool subnet
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 497 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
