Change default pop3 and smtp port for email security
Pikappa
Pikappa Posts: 2 image  Freshman Member
edited April 2021 in Security
a stupid question ... I didn't find how to change the default pop3/smtp port that email security scans. I use different accounts in our network with different ports and none uses the default ports
Thanks?
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,401 image  Zyxel Employee
    Hi @Pikappa
    Welcome to Zyxel community
    Here is the command to specify the port
    Router(config)# utm-manager anti-spam defaultport <1..65535>
    Check defaultport by the command
    Router(config)# show utm-manager anti-spam defaultport
    Since you have the same post in another thread, we will remove the duplicated one.
  • Pikappa
    In the manual there is a section that reports:
    "The Zyxel Device’s email security feature checks SMTP (TCP port 25) and POP3 (TCP port 110) emails by default. You can also specify custom SMTP and POP3 ports for the Zyxel Device to check. " but there is no further instruction (!?)
    So .. Where/how can I specify the ports ?
  • Zyxel_Jerry
    Hi @Pikappa
  • Frabre
    Frabre Posts: 11 image  Freshman Member
    edited October 2024
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,239 image  Zyxel Employee
    Hi @Frabre,
    Please use "Router(config)# no utm-manager anti-spam defaultport <1..65535>" to delete.
    If you don't know which port is incorrect, please use "Router(config)# show utm-manager anti-spam defaultport" to check.
    Zyxel Melen
