No default set to open without a random password on all AP shipped
So found out the embarrassing way when checking my traffic the short of it is I setup a AP as Repeater it was on the guest network so its isolated but still can't believe I made this mistake that can happen very easily due to the default set to open and when you make the SSID it set to use the default for Security Profile. I managed to set all the other networks with the right Security Profile just not for the guest network.
Summarize:
I wish for the default to not be set to open just by default its set to WPA2/3 with a random Pre-shared key that can then be changed after.
Hi @PeterUK,
So your purpose is like your title "No default set to open without a random password on all AP shipped"?
Zyxel Melen0 -
So yes as one will be configuring the AP by Ethernet just set a random password per AP for the default Security Profile no need to list it really.
Hi @PeterUK,
The latest firmware(V7.00) requires users to change the default SSID setting and security at the first time via the wizard.
Does this fulfill your request?
Zyxel Melen0 -
Its does not fulfill my request I wish for the default to not be set to open just by default its set to WPA2/3 with a random Pre-shared key that can then be changed after.
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 516 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.3K FAQ
- 97 Security Highlight
