NWA50AX NWA50AX_7.00(ABYW.2)C0 SSID pass key not visible
aks
aks Posts: 10 image  Freshman Member
In the past (I thought) it was possible to read the SSID passkey (pre-shared key) under the security list/profile, but with V7.00P2 this is now just stars:
I have not enable the extra encryption in the config settings:
However, I notice the config files also now encrypt the SSID passleys, however, this was not the case for the 6.xx firmwares.
So my question is, how do I view in readable format the passkeys for the SSID configs, as I don't have another easy way to maintain them? (yes, I could write them in another file/paper/etc, but that's not ideal.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,347 image  Zyxel Employee
    Hi @aks ,
    In recent firmware versions, we have made the Pre-Shared Key (PSK) hidden to enhance security. This reduces the security issues. For your protection and the overall security of the network, the PSK is intentionally hidden, and there is no option to display it in the GUI.
    Regarding the Sensitive Data Protection feature, it can be enabled, allowing you to enter a Private Encryption Key. When this feature is activated, user passwords in the configuration file are encrypted using a custom key, further enhancing security. However, this feature is unrelated to the visibility of the PSK.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @aks ,
    Zyxel_Judy
    Untitled Image
  • aks
    edited October 2024
    As the system admin, I would expect to be able to view this in the GUI, like most other equipment I'm using, not to mention the access I must already have if I've logged in to the admin console, so this behaviour seems unnecessary.
    Sure I can see why encrypting the config files makes sense.
    Please consider allowing admins to enable viewing of the WiFi passwords, and accepting the associated risk.
  • Zyxel_Judy
    Hi @aks ,
    Thank you for your feedback. We understand your concern regarding the visibility of the PSK in the GUI for system administrators. We will carefully evaluate this feature.
    Zyxel_Judy
    Untitled Image
  • aks
    Thank you.
    Are you able to provide any information when this might get considered, it's quite a nuisance!
    Also, do you have a suggested workaround or patch, or other suggestion?
  • mMontana
    mMontana Posts: 1,469 image  Guru Member
    I cannot agree more.
    Capability to unlock that view in some role might be useful in some scenarios.
  • aks
    @Zyxel_Judy did this request come up for consideration yet?
  • Zyxel_Judy
    Hi @aks ,
    The request is currently under evaluation. Currently, there is not a confirmed timeline for implementing this feature.
    Please monitor the Wireless Notes & Releases for updates on new features and enhancements.
    Zyxel_Judy
    Untitled Image
