Series H - Different SecuReporter details?
GiuseppeR
GiuseppeR Posts: 658 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
I used to see this dashboard on SecuReporter, for example here you can see a view from a Flex100 site:
That is different from the view seen on a Flex100HP site:
I have the same situation comparing a Flex200:
and Flex200H:
What I have to do to have the same view everywhere?
Is the Flex H series the new welcome UI for SecuReporter?
Thanks in advance
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,602 image  Zyxel Employee
    Hi @GiuseppeR,
    May I know your point is on the Traffic usage vs Threat detected by functions?
    Zyxel Melen
  • GiuseppeR
    edited October 2024
    Hello @Zyxel_Melen
    yes it is related to quick access from Dashboard to ADP, IP Rep., IPS etc. that is not available with FlexH.
    Traffic usage stats could be useful but having a quick view on all the threats was very helpful to have a sight about its healthy
    It could be perfect to have a virtual switch to show/hide some options, creating the perfect dashboard adding widgets like you can do inside Nebula
  • Zyxel_Melen
    Hi @GiuseppeR,
    Thanks for your input. May I know if the dashboard adds all threats graph view between the security indicator and the traffic usage meets your requirement? I want to clarify the possible way first.
    Zyxel Melen
  • GiuseppeR
    edited October 2024
    Hello @Zyxel_Melen
    I have no graph like this in the dashboard related to my FlexH firewalls:
    This graph is nice to have a quick view about all these threats.
    Could I have misunderstood your question?
    PS: I still see a blank map on my SecuReporter page of a 200H
  • Zyxel_Melen
    Hi @GiuseppeR,
    Thanks for your feedback. I'm clear now.
    About the blank map issue, I will message to request the org name to check.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR,
    After checking with my team, please help to access your H series firewall and navigate to Menu > Log & report > SecuReporter to unselect the "Traffic Log" option. This option will affect the SecuReporter dashboard display. In other words, the SecuReporter dashboard display is dynamic. Our team thinks when the user selects the "Traffic Log" option, she/he is focusing on this information. So, we will display the traffic usage on the SecuReporter dashboard.
    Zyxel Melen
  • GiuseppeR
    edited October 2024
    Hello @Zyxel_Melen
    every option was selected since the first installation of that Flex H series FW:
    The same happens with all the other Flex/ATP series.
    I need to send Traffic Log to SecuReporter to know which IP is communicating in/out and why, which port, how many gigs of traffic is sent/received and so on.
    All the statistics of the FW are needed, it is mandatory.
    I'm going to send you Org name on Nebula via PM, so you can check the FW.
  • Zyxel_Melen
    Update:
    Our team will evaluate this request. I also help create an idea post. If anyone likes this idea, please leave your comment and give it a vote. Our team will also monitor the count of votes and comments.
    Zyxel Melen
