Trunk configuration
Gel
Gel Posts: 35 image  Freshman Member
edited October 2024 in Security
I have two WANs with 200MB Full each. How do I make it so that when WAN1 goes down, WAN2 goes up automatically?
Do I need to configure something in routing besides creating the trunk?
How do I create Trunk so it works this way?
I'm using the USG FLEX 200
  • Gel
    I tried to configure it with trunk and it didn't work. I'm putting some images to see if I made the right configuration.
    where I circled in red, is the configuration correct? Does it have to be like that?
    In the routing option, in the route policy, when editing my LAN1 in nexte-rop, do I put trunk? Could it be that when WAN1 goes down, WAN2 goes up automatically?
    Would this be the configuration? Thanks in advance for your attention. Thank you very much.
  • zyman2008
    zyman2008 Posts: 242 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    Hi @Gel ,
    Just setup a Trunk and set it as default.
    1. Create a new Trunk. Set the primary link ac active mode and backup link as passive mode.
    2. Select this Trunk as default
  • Gel
    edited October 2024
    @zyman2008
    Thanks for the information. One more thing: In my corporate network I created a routing so that the internal LAN1 leaves via WAN1. With this change in the trunk that you told me about, what would this runting look like? Do I have to delete it? Or should I do some other configuration so that it works the way I said, if WAN1 goes down, WAN2 goes up and we don't run out of internet?
    Thank you very much for the help.
  • valerio_vanni
    valerio_vanni Posts: 157 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    Yes, this way LAN1 can go out only on WAN1.
    You should create another policy route for LAN1.
    #1 pointing to WAN1
    #2 pointing to WAN2
    Both with "healthy check". So, if WAN1 is working, #1 is used. When WAN1 is down, #1 gets disabled and #2 is used.
  • zyman2008
    edited October 2024
    Hi @Gel,
    Change the next-hop of this policy route to the new Trunk.
    Note: you need to enable and setup connectivity check in the primary interface.
    What valerio_vanni mentioned is also a solution.
    My preference is to use trunk to set up. It makes the policy route table cleaner. Too many rules often make it difficult for me to debug.
  • Gel
    would it be like that? Instead of interface, put configured trunk
    Would this be a second option?
  • valerio_vanni
    Yes, trunk method is simpler than mine.
    You can SNAT to outgoing interfaces, I use the other method because I have to SNAT to different addresses.
  • Gel
    Thank you everyone for the information. Next Saturday I will make the changes and see how the network behaves. Once again thank you all very much.
  • Gel
  • Gel
