Cannot connect VPN IKEv2 to usg 100
Franz94370
Franz94370 Posts: 9 image  Freshman Member
I have configurate a IKEv2 VPN connection but each time i cannot connect and i saw this error message in the log
2024-10-17 07:55:12
warn
ADP
Rule_id:1 from WAN to Any, [type:UDP-Decoder(74)] oversize-len Action:Drop Packet [count=3]
V5.39(ABUH.0) / 2024-08-22 06:21:11
Can you help me ?
Best regards
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    Hi @Franz94370,
    This is more likely due to the other side of the IKEv2 VPN sending over-size-length packets. What is the device that connects to USG FLEX 100? If it is site-to-site VPN, are the VPN configurations on both the routers/firewalls the same? (MSS)
    In addition, if this device is trusted, you can set the ADP allow list to bypass the traffic. The rules below screenshot an example, you might need to adjust to fit your network.
    Hope it helps.
    Zyxel Melen
  • Franz94370
    Thank you for your answer.
    I tried to create the rules but cannot connect.
    Configuration is VPN Client to site.
    I try tout connect on a Win10 Pc using the built in Windows client
    The USG is connected upstream on a Dray Tech router and a DMZ has been configurate on 192.168.8.2 and my computer IP is 90.0.142.50
    I am sending you log of the screen
    shot
    I have tried to modify the parameter UDP LEN ATTACK in ADP but it is the same.
    What can you suggest
    PeterUK Posts: 4,427 image  Guru Member
    edited October 2024
    Disable ADP and see if it connects
    is the connecting device set with Jumbo packet disabled or set to 1514
