VLans on Zyxel GS3700-24 (Firmware V4.30(AAFY.1))
Hello everybody.
I am trying to configure some ports on the above switch with vlans.
I successfully configured 2 ports has vlan trunks.
On the ports i want to configure the vlans, i have computers connected. So, they aren't tagging vlans, the switch need to tag them.
Regards
Regards
Hi @Webix
Welcome to the Zyxel community!
Based on your description, you should also configure corresponding PVID for the ports connecting to PCs, and do remember to set as untagged-out.
Hope it helps.
Zyxel_Lucious
5
Hi @Webix
Hope it helps.
Zyxel_Lucious
5 -
That solved it. Thanks0
- 588 USG FLEX H Series
- 477 News and Release
