USG200H rebooted itself, Netconf RPC errors
PW44
PW44 Posts: 1 image  Freshman Member
edited October 2024 in USG FLEX H Series
Hi
After about 80 days of continuous operation, the device rebooted itself. Before and after this reboot, the following errors are shown:
I have noticed other problems with this device:
  1. long lists (DHCP IP, NAT, Log, Security Policy) are super slow.
  2. the interface was better and faster in previous models (e.g. Flex 200, USG200)
  3. after an uptime of about 70 days, I had problems setting up port forwarding
  4. don't see an option for automatic restart according to schedule
Firmware V1.21(ABWV.0)
  • Omnia
    Omnia Posts: 60 image  Ally Member
    we have the same issue and persist after reboot
  • Dylan96
    Dylan96 Posts: 35 image  Freshman Member
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
    same issue on our 500H - fw: V1.21(ABZH.0)ITS-24WK35-m5760
    PeterUK Posts: 4,429 image  Guru Member
    edited October 2024
    I see them too likely they know about them but when you login in again errors go away, unless yours don't?
    and then the UI become unstable after a far days☹️
    USG FLEX 200H V1.21(ABWV.0)ITS-24WK35-m5760
    mugshot of UI after reboot
  • bbp
    bbp Posts: 70 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    I'll join the party…
  • DanniKool
    DanniKool Posts: 49 image  Freshman Member
    First Answer First Comment Seventh Anniversary
    New firmware v1.30 will be released this monday - it should fix the WebGUI issue. Let's see if it will fix the random reboot issue too……
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,320 image  Zyxel Employee
    Hello Users,
    We are pleased to announce that the latest firmware version (1.30) for the USG FLEX 200H has been released today. Please proceed with upgrading your device and let us know if the issue you encountered has been resolved.
    Zyxel_Judy
    Untitled Image
