Firmware Upgrade Procedure GS1910-48HP
The release notes with the V2 firmware suggest that the upgrade procedure is to go from 1.00(AABA.0) to 1.00(AABA.2) and then 2.00(AABA.0). Have I understood that you can't go from 1.00(AABA.0) directly to 2.00(AABA.2)?
If that's true where can I download version 1.00(AABA.2) to do the intermediate step?
Hi @KenS
Sorry to cause your inconvenience, we'll PM you for the requested 1.00(AABA.2) firmware.
Zyxel_Lucious0 -
Thank you - that's arrived. Much appreciated
I have the same issue for both the GS1910-48HP and the GS1910-24HP. Thank you!
Just go to ftp.zyxel.com, pick the device name from the list of directories, and then select the firmware directory.
You should see a list of the various firmware versions that you can download for the device.
It is some time ago this was a subject, however I too need the Firmware version 1.00(AABA.2) in order to be able to upgrade our GS1910-48HP. And yes I checked at ftp.zyxel.com and found only newer ones.
Thanks for helping me in this regard
Hi @Urs ,
Welcome to Zyxel community.
Please refer to the link below for the firmware of GS1910 series.
GS1910-24
GS1910-24HP
GS1910-48
GS1910-48HP
For example, GS1910-48HP V1.00(AABA.2)
Hope it helps.
where is now stored firmware for GS1910 48HP ?
Thank you
- 212 Nebula Ideas
- 548 USG FLEX H Series
- 341 Security Ideas
- 295 Service & License
- 468 News and Release
