V1.30 stuck booting
So I upgraded to V1.30 all seemed to be working went and changed a setting and the UI locked up so I did the only thing I could and unplug it and plug it back in again 10 minutes later its still booting.😥
Hi @PeterUK ,
We have confirmed that there is a configuration conversion issue when upgrading from firmware version 1.21 to 1.30 with your configuration. We have shared a firmware update that includes a fix for your case via the private message. This solution will also be incorporated into the next official firmware release.
Did you manage to restart it? Should we wait to update the firmware?
I think its bricked can't seem to get to it by COM either
suggest not updating at this time if I can't recover from it
I did backup my config on V1.30 before rebooting for Zyxel team to look if they want to PM me
update with COM hooked up I see starting services and config-apply… with moving …. and ####
I will give it 20 minutes and hope it boots
So at 20 minutes this happened so its now rolling back to the other slot should see it boot in 5mins
config did not load so reset was done just waiting for it to boot again on V1.21
Ok so I'm back on defaults of V1.21
Trying V1.30 again and now its stuck starting services and config-apply don't think it will load this time
It failed to load V1.30 this time😪
I'm not going to risk it yet, until they have all hands on deck (in about an hour or so).
Thanks for warning! Appreciated.
I see they have removed it from Nebula
It seem the config was reordered loaded fine but a simple change locks up the the UI then when you unplug it to plug it in again the config is corrupted and after 25 minutes you load back to the other firmware slot
@Zyxel_Melen Any updates on the situation?
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 457 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
