VLANs and gs1200-5
dorman_142
dorman_142 Posts: 1 image  Freshman Member
I'm new to VLANS and trying to set one up adjacent to my default vlan.
I'm aware I need a router that supports VLANS and so I got an edgerouter x, and set it up to work as a standard router, using my ISP router in bridge mode. This works fine.
I then added a VLAN subinterface for switch0 on my router - which is VLAN aware for eth1-4. I have also added a DHCP service on my router for the IP address on my VLAN subnet.
On my switch I have set untag egress on VLAN 10 for both ports, and disabled on VLAN 1.
From my understanding:
I should not be able to access management on these ports,
And I should have connectivity between the two devices on the ports.
I should be able to ping my switch (which should able to send traffic to the router)
I should have internet conenctivity
What I am seeing is:
I am not able to access the switch management using these ports
I do have connectivity between the two desktop devices.
I an NOT able to ping my switch's management IP address - is this correct?
I do NOT have internet access
Obviously I've done something (or a few things) wrong, but I'm struggling to understand exactly where. Is anyone able to lend a hand?
    PeterUK Posts: 4,446 image  Guru Member
    Not too sure about edgerouter UI maybe you need pvid not vid?
    Or maybe try without a switch0
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    edited October 2024
    Hi @dorman_142
    Your VLAN settings on GS1200 seem perfect.
    The PC cannot access the Internet might need to check the router's settings, like the routing setting.
    The switch is not pingable need to check if your switch has a default gateway setting.
    Zyxel Melen
