Fate/Time on NWA-50
CnlHub
CnlHub Posts: 2 image  Freshman Member
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    edited October 2024 Answer ✓
    Hi @CnlHub ,
    We recommend checking the DNS settings, you might try changing the DNS to 8.8.8.8 .
    You should also check if port 123 is blocked. If it is, please open port 123, as it is required for the NTP protocol to function properly.
    Additionally, for time synchronization, you can use servers such as time.google.com or 0.pool.ntp.org.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @CnlHub ,
    It sounds like you're having some trouble setting up "Fate/Time" on your NWA-50AX. To better assist you, please provide more information about the specific issue you're experiencing. For example:
    • What exactly are you trying to achieve with "Fate/Time"?
    • What error messages, if any, are you encountering?
    Zyxel_Judy
    Untitled Image
  • CnlHub
    edited October 2024
    Should have been Date/Time. Am trying to have my standalone NWA50 maintain its date/time automatically. Tried "time.windows.com", "time.apple.com", and several others without success. My NWA210AX works fine with an NTP site, even that will not work with my NWA50.
  • Zyxel_Judy
    Hi @CnlHub ,
    Zyxel_Judy
    Untitled Image
