Updating to V1.30 if on ITS
PeterUK
PeterUK Posts: 4,418 image  Guru Member
So for anyone seeing this you have to be on V1.21 non ITS so you have to run a slot with this if you don't have a slot with V1.21 which I did but likely you have to do this which is update by Nebula which will only install V1.21 on your standby slot then on the UI of the Flex H can you upgrade to V1.30
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,593 image  Zyxel Employee
    Hi @PeterUK,
    This is to prevent the fix of the date code firmware that isn't included in the new official firmware. In addition, this only affects the cloud firmware upgrade. You still can manually upgrade the latest firmware.
    Zyxel Melen
  • Zyxel_Melen
    Hi @PeterUK,
    Zyxel Melen
