NebulaFlex Switch XGS1930 Series - V4.70 Patch 8 Firmware Release
Zyxel Switch XGS1930 Series Release Note
September 2024
Firmware Version on all models
(Click hyperlink to download the firmware directly)
Zyxel XGS1930-28HP - V4.70(ABHS.8)C0
Zyxel XGS1930-28 - V4.70(ABHT.8)C0
Zyxel XGS1930-52HP - V4.70(ABHV.8)C0
Zyxel XGS1930-52 - V4.70(ABHU.8)C0
New Feature and Enhancements
1. [Standalone] Enhance security by forcing users to change the password after first login.
2. [Standalone] Support Zyxel Private MIB.
- Hardware Monitor
- Power Ethernet
- Transceiver
3. [Standalone][Nebula] Expand NTP servers from 1 to 3.
Bug Fix
| Bug fix | C | S |
| 1. [eITS #240100009] Fixed memory leak issue causing packet switching failure when the switch configures a non- existent IPv6 gateway and receives Bug fix Nebula Standalone numerous unknown IPv6 packets. | - | V |
| 2. [eITS #231201249] Fixed switch may reboot automatically when receiving IPv6 packets. | - | V |
| 3. [eITS #230801482] Fixed an issue causing the switch to repeatedly switch from standalone mode to cloud mode leading to switch offline. | V | - |
| 4. [eITS #240300246] The switch hangs when an IPv6 client roams. | - | V |
| 5. [eITS #240500205] Switch hang when click PD "Reset" via Neighbor page. | - | V |
| 6. [eITS #240501702] Fixed device IP address and uplink usage are not displayed correctly on Nebula. | V | - |
| 7. Fix the issue where checking the IPv6 routing table on the web causes the device to crash. | - | V |
| 8. [eITS #240601476] Continuously collecting the tech support file may cause the device to crash. | V | V |
| 9. [eITS # 240601476] Using SNMPwalk to query the Q-Bridge MIB will return incorrect values when voice VLAN is enabled on the device. | V | V |
Please refer to the Download Link for more details.
Thanks for the adding the Private MIB support. The extra SNMP data is really useful.
I was expecting this highly anticipated update to be in the form of a V4.80 update with the revised webUI. This is based on a post made by a Zyxel rep in this community back in March.
Is a V4.80 update still in the pipeline?
Thanks for your input. I have let our switch product team know your voice. I will keep you posted if we have any updates.
Zyxel Melen1 -
Thanks @Zyxel_Melen
I can quote the post made by your colleague on March 18th if needed.
I am also interested to see the 4.80 look and feel on the XGS1930 Series.
Would be great and streamline administration.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
