V1.30 stuck booting
Will be doing more testing later today but I think it has to do with the bridge.
Hi @PeterUK ,
We were unable to reproduce the issue you're experiencing. Based on your description, we suspect there may be some configurations that are incompatible with firmware version 1.30. To help us investigate further, could you please provide the following information:
- Go to Maintenance > Diagnostics > System Logs and download the boot-config-error file.
Navigate to Maintenance > Firmware/File Manager > Configuration File and download the configuration file that includes the date, and any differences compared to the three files listed below.
Zyxel_Judy
PM sent
and in the mean time doing my config again from defaults on V1.30☹️
So I'm now 99% config to V1.30 now and with no trouble I did some copy and paste to get most of it done.
I don't know where in the config caused such a problem.
Hi @PeterUK ,
We have confirmed that there is a configuration conversion issue when upgrading from firmware version 1.21 to 1.30 with your configuration. We have shared a firmware update that includes a fix for your case via the private message. This solution will also be incorporated into the next official firmware release.
Zyxel_Judy
My firewall UI and SSH are no longer working at all after upgrade to 1.30.
Is there still no official release? Can you please share the updated firmware to fix?
Thanks0 -
Hi @SP84 ,
Could you tell us which model and firmware version you are using - is it 1.30P0 or 1.30P1?
Zyxel_Judy
- 441 Beta Program
- 293 Service & License
- 461 News and Release
