how to have access with certification enabled
OrgInf
OrgInf Posts: 2 image  Freshman Member
edited April 2021 in Security
For a mistake I have enabled the certification and I have lost the connection with the ATP.
How can I have access to ATP?
  • zyman2008
    zyman2008 Posts: 243 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    If what you means is the client certificate authentication.
    Then login device by serial console or SSH, and here the command to disable it.
  • OrgInf
    Thanks lot for your help, the problem has been solved.
