How to configer Synology DS 1815+ on Zyxel GS 1920 /24
Hi
I have made a bond with 2 adapters on my syno
Now I want to start using Virtual Manager and get the following
then I go to the bond - Verwalten - Vswitch settings
Now I don't know how to configure what.
I think I need Port aggregation in the Zyxel, but do not know how to set this up correctly
Pls help me newbie to get this working correctly
many THX for your patience
Hi @Witzker,
If you want to set link aggregation(a.k.a static trunk, EtherChannel) or LACP, you have to follow the below steps:
- Set link aggregation(in Synology is Balance XOR) or LACP on Synology.
- Reference this FAQ to set link aggregation(a.k.a static trunk, ether trunk) or LACP:
How to enlarge your bandwidth or enhance your network reliability by link aggregation? — Zyxel Community
If you want to use other modes, please check with Synology support about what you should do on the switch side.
Zyxel Melen0
Hi @Witzker,
Zyxel Melen0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
