HTTP port for the UI don't load
PeterUK
USG FLEX 200H V1.30(ABWV.0)
Redirect To HTTPS is disabled
You can load the log in screen click login and get a blank screen
I solved it I had to do CTRL + F5
Hi @PeterUK ,
We disabled the "Redirect to HTTPS" option, but we were still able to log in to the USG FLEX 200H's local GUI.
Could you provide WAN access so we can directly check your device?
Zyxel_Judy
- 600 USG FLEX H Series
- 480 News and Release
